2003 c320 4matic
Old 03-28-2017, 11:32 PM
Kris_2003's Avatar
Default 2003 c320 4matic
I am having a problem with my passenger door the courtesy light under the door doesn't turn on even when you open door or turn the door lights to stay on and dome light doesn't turn on when you open door either all other doors work perfect checked the bulb and replaced with new bulb same problem does anyone know what it can be makes no sense even if the door sensor was messed up it would still turn on when you turn the lights to on right? Can someone please help me
Old 04-07-2017, 03:20 PM
Try getting the codes ran, if there is an electrical issue or fuse related; this will give you a good place to start troubleshooting.
-Dmitry
Old 04-07-2017, 08:36 PM
Kris_2003's Avatar
All bulbs and fuses are good
-Dmitry
Old 04-25-2017, 04:22 PM
Even if the fuses and bulbs are good, the DTC could have stored codes.
goblue20
11-27-2011 06:34 PM
4MaticMan
07-07-2008 04:51 PM
C280 SPORT
03-21-2008 02:14 PM
justino
01-11-2006 04:35 PM
BostonTurtle
08-16-2005 09:01 PM
Quick Reply: 2003 c320 4matic
