WATER & OIL\ WHY???
Old 01-08-2008, 07:00 PM
oukno's Avatar
Default WATER & OIL\ WHY???
I have a 1996 C220 that just had a head gasket replaced by a local shop and I'm still getting water in my oil any one know why???
Old 01-09-2008, 12:48 AM
snanceki's Avatar
Default RE: WATER & OIL\ WHY???
Possible that fault was not head gasket. Could be even worse and be a crack in the head/block.
However, does your engine have a modine water/oil type oil cooler.
If so mixing has been known to occur at this point.
Suggest you remove cooler and pressure check.
Stuart
Old 01-09-2008, 02:22 AM
sleepwalker's Avatar
check the oil cooler. that's where the oil and water could mix.
it is attached to the oil filter housing.
Old 08-10-2008, 02:48 PM
mikehummer69's Avatar
I'm getting oil in my coolant, could the oil cooler be the entry point? I had the rad replaced a month ago and the problem is back. I can't be sure if it's tranny fluid or engine oil. But my engine oil is disappearing rather fast.
Old 08-10-2008, 10:51 PM
yes if you have M104 engine.
Old 08-10-2008, 11:56 PM
snanceki's Avatar
You say oil is disappearing fast.
However, Is oil appearing in the coolant?
Oil Cooler can be the problem if the engine is fitted with a "modine" oil/water type cooler.
Stuart
johnny cruz
11-23-2010 08:30 AM
mbgt
12-17-2009 01:12 PM
speakernut
12-08-2008 07:54 AM
fdo_hidalgo
05-14-2007 01:36 PM
ska
06-11-2005 11:15 PM
Quick Reply: WATER & OIL\ WHY???
