Replace antenna mast?
Old 05-25-2015, 03:24 PM
lindajane's Avatar
Default Replace antenna mast?
My antenna failed to go down far enough and got bent in a car wash....
So I ordered a new mast. My mechanic said he'd put it in for $20.
Now If I can do it, I'd rather. I saw a youtube how to video and it
called to open part of the trunk. Is there anything tricky about putting
in a new mast?...It has the steel part, and a smooth white cord.
Thanks!
Lindajane
Old 05-29-2015, 02:48 PM
handygeek's Avatar
I would think that you just have to watch the way that the rubber grommets seat so you don't get leaks. I've never done the job so can't help from experience.
Old 06-05-2015, 06:49 AM
dreamer no2's Avatar
Just done this .First you need to remove the ariel and its rubber grommet.Because if the plastic gear drive breaks inside it will leave broken bits inside .If you put the new gear drive in it will break it .All instructions in the packet that your new mast will come in . To find out the right mast insert you want, you can find the number on the very end tip. You just feed the new mast drive in as someone turns on the radio ,it will take the new part in and stop , then you lock up the nut with a wrench.Any problems pm me.
techteam
08-11-2010 03:14 PM
Chadted
08-23-2008 06:34 PM
apollo_10
11-04-2006 03:23 PM
81 300 CD
08-20-2006 12:39 AM
benzowner
05-11-2005 11:50 PM
Quick Reply: Replace antenna mast?
