240D engine temperature
Old 05-07-2005, 04:21 AM
chelica1's Avatar
Default 240D engine temperature
Hi all,
I've just bought a 83' 240D with manual transmission and spent last week fixing some minor problems (vacuum leek). The car runs fine although I feel its very slow and without power especialy going uphill (my father had W124 200D and 250D and they were both much quicker and felt stronger, especialy the later). I know that 230K is not a low milage but I bought this car knowing that these engines are durable. Its starts on a single crank, makes 28+ MPG and keeps the oil presure at 2bar at idle and thats were I left out of ideas to look for the cause. Does anyone know what is the normal engine temperature for this car, as mine never gets to 80 and is usualy just above 40. This looks suspicious to me. All tips are welcome.
Old 05-07-2005, 04:31 AM
sleepwalker's Avatar
Default RE: 240D engine temperature
is normal
Old 05-07-2005, 05:53 AM
Your thermostat is never closing properly. You should see engine temp above 80, as that's when it should start to open. Get a new one. You'll probably get much better power.
Old 05-07-2005, 07:20 PM
Sounds like you need to replace the thermostat. It should come up above 80c within a few minutes of driving and remain in or around 80c, 85c, but not beyond 90c.....normally.
Old 06-18-2005, 12:32 AM
dont worrie unless gets over ....110c that norm ..in summer time
builderdude
09-16-2010 11:17 AM
Le2dynasty
11-06-2009 06:35 PM
mbenzer
07-13-2005 10:22 PM
pjcc
06-20-2005 01:24 PM
CCCP
03-06-2005 11:41 PM
Quick Reply: 240D engine temperature
