Vendors Special Buys See what our AUTHORIZED vendors have for you in here.
Replace Your W210's Serpentine Belt This Weekend! By Pelican Parts
Old Oct 16, 2013 | 10:29 AM
PelicanParts.com's Avatar
Sponsor
Default Replace Your W210's Serpentine Belt This Weekend! By Pelican Parts
One of the routine maintenance items that you should perform on your Mercedes-Benz is the checking and replacement of your serpentine belt. The belt is driven off of the crankshaft and turns the water pump, fan clutch, alternator, and air conditioning compressor. The belt should be checked periodically (for example, when you change your oil).
When inspecting your belt, the one thing that you want to look for is cracking on the underside of the belt. This needs to be watched as over time excessive cracking can cause the belt to fail. On the outside of the old belt will be a number that indicates the width and the length of the belt. Use these numbers when ordering a new belt to make sure the replacement is the same as the old one.
Are you ready to change your belt? Shop here for the correct belt for your W210 Mercedes-Benz.
If you'd like guidance when replacing your belt, let us know and we'll walk you through it!
Mark/Pelican Parts
Old Oct 22, 2013 | 06:41 PM
Sponsor
Great info, thanks for sharing!
Mark/Pelican Parts
PelicanParts.com
Sep 20, 2013 06:55 PM
PelicanParts.com
Aug 12, 2013 02:14 PM
PelicanParts.com
Jul 22, 2013 12:15 PM
PelicanParts.com
Jul 3, 2013 11:31 AM
PelicanParts.com
Jun 25, 2013 11:45 AM
