Need To Replace Your ABS Wheel Speed Sensors? Parts In Stock Now! By Pelican Parts
The ABS wheel speed sensor on the Mercedes C320 monitors road wheel movement and sends an electronic signal to the ABS module. This signal is used to calculate road wheel speed to help with ABS braking and stability control features. When an ABS wheel speed sensor fails, the ABS module loses road wheel speed for the corresponding wheel and sets a fault code for ABS wheel speed signal. When a fault code is set, the ABS warning light will illuminate. You will have to scan the module and read the fault codes to determine which speed sensor is the problem. Keep in mind, other problems can illuminate the ABS warning light, be sure to scan and read fault codes before you start replacing expensive parts.
We offer Genuine Mercedes-Benz sensors ready to ship today! Click below for further product details: Genuine Mercedes-Benz ABS Sensors for the C320 Let us know if you'd like install instructions for this project - happy to assist! 888.280.7799 |
