Faulty MAF Sensor In Your W203 Mercedes? Genuine Parts In Stock From Pelican Parts
Having issues with your Mass Air Flow Sensor? The (MAF) is used to measure the amount and temperature of air that is entering the engine at any one time. The mass air flow sensor senses the total amount of air passing the sensor and allows the fuel injection system to adjust the fuel mixture to compensate for cold weather and/or high altitude conditions. The MAF also incorporates an internal intake air temperature sensor which measures the temperature of the intake air.
The first indicator that you might have a problem with the MAF is the presence of a check engine light (CEL) on your dashboard. The check engine lamp can be caused by a wide variety of problems with the engine: you need to read the codes from the computer to get a starting clue as to what the problem is. If the sensor is the issue, shop for Genuine Mercedes-Benz parts here! Let us know if you have any questions! Mark/Pelican Parts |
