Broken Window Regulator Driving You Nuts? Replacements in Stock at Pelican Parts!
Are you hearing a crunching, grinding noise every time you press the window switch? Is the window not moving? Chances are, your window regulator has broken and must be replaced. This is an item which has a long history of failure. Replacement involves removing the inner door panel and drilling out the rivets.
We have the parts you need for your W210 Mercedes! Click here to shop for parts for your specific application. Let us know if you have any questions or need install instructions. Mark/Pelican Parts |
