Other Post discussion on all other models not listed above here.
whineing noise 2.3 cosworth
Old Apr 24, 2005 | 10:29 PM
turbo's Avatar
Default whineing noise 2.3 cosworth
Hi can anyone help, when engines hot i get a whineing noise comming from the power steering area checked fluid its ok cant hear it unless driving with window down dosent affect preformance just annoying makes engine sound rattlely and tappety could the belt be loose? dosent feel so, also the dogleg gearbox gives a rattle but once clutch is pressed its fine.
cheers darren(scotland)
Old Jun 21, 2005 | 01:15 PM
muso58's Avatar
Default RE: whineing noise 2.3 cosworth
if you can hear it when standing still ,remove the belt and see if noise dissapears .it will help you to narrow down your search
Old Jan 5, 2007 | 12:13 AM
Danielvito113's Avatar
The clutch noise sounds like the thrust bearing.
Leave it till the clutch is worn out or the bearing fails, (big job)
190eCosworth
Dec 31, 2006 11:19 AM
Cosworthpower
Dec 25, 2005 01:42 PM
gavin cass
Oct 22, 2005 05:04 PM
McLaren118
Jan 29, 2005 02:08 AM
jocor
Jul 29, 2003 04:17 PM
