Mercedes 300 trans problem
I switch trans awhile ago and i had to switch the machanical speedo sensor that is on the new trans back to the electronic speedo that was on the old one. My problem is that the trans will not change gears, the fluid is good.
RE: Mercedes 300 trans problem
Maybe you need to adjust the cable control wire or the modulator pressure , but what is the number of the case . ( 722,4 )
