81 300SD Turbo Boost Adjust....?
Ok... So i hooked up a pressure gauge before i did anything (see pic)
http://home.earthlink.net/~arcless/gauge.jpg Adjusting what "looked" like the BOV one or 2 turns in either direction did nothing (see pic) http://home.earthlink.net/~arcless/bov.jpg So then I realized that the Wastegate needs to be adjusted... But there isnt any adjustments that i can see... Soo I did something tha I KNOW shouldnt be done... I unhooked the wastegate hose form my tee.. and pugged the tee so my gauge still worked. then brove it about 3 blocks to see how much PSI i'd get. It got up to 21PSI. Knowing the sin that i Had commited I hooked it back up Correctly before I drive back home. SO what do i do here? I want more Boost! dont get me wrong... im not racing this thing... I just like to make improvements to things by adjusting whats available on the car :^) Ive heard more boost and adjusting the ALDL SLIGHTLY can make a difference... any thoughts? oh.. and i put on an "ultra spiffy" intake system.. (see pic) http://home.earthlink.net/~arcless/intake.jpg PVC pipe and a coupler with a cone filter. Thanks in advance for any ideas! -Dan |
RE: 81 300SD Turbo Boost Adjust....?
Nevermind! i searched the forum and found all the info i needed
thanks! -Dan |
could you post a link to what you found thanks
| All times are GMT -5. The time now is 08:33 AM. |
