1997 CLK GTR D2
RE: 1997 CLK GTR D2
Their road race version was raced in the 98 FIA GT championship, 1998 Le Mans, 1999 Le Mans, and various WSC championship rounds in the US
Built to FIA-GT specs
Victories not known. (I don't watch racing or care who wins.)
$1,000,000 ballpark price range
This took some time to find all this.
CLK-GTR SPEC
Powertrain Layout Mid Engine / RWD
Dimensions
WheelBase - 2670 mm
Length - 4854 mm
Height - 1102 mm
Width - 1951 mm
Weight 1000 kg
Front / Rear Track
Front - 1600 mm
Rear 1600 mm
ENGINE
Configuration V12
Valvetrain DOHC, 4 valves / cylinder
Displacement - 5987 cc
Power- 600.0 bhp @ 7000 rpm
Torque - 516.0 ft lbs @ 3700 rpm
Bore - 89.0 mm
Stroke - 80.2 mm
Compression Ratio
12.0:1
Redline 7800 rpm
TRANSMISSION
Type 6-Speed Manual
Final Drive 2.88:1
1st Gear Ratio 2.71:1
2nd Gear Ratio 2.20:1
3rd Gear Ratio 1.80:1
4th Gear Ratio 1.52:1
5th Gear Ratio 1.33:1
6th Gear Ratio 1.18:1
CHASSIS
Steering Rack & Pinion w/ Power Assist
Tire Sizes
F 280/35R-18
R 330/40R-18
Brake Types Vented Carbon FIbre Discs
Brake Size
F 381 mm / 15.0 in
R 356 mm / 14.0 in
Body Material Carbon Fibre
PERFORMANCE
Top Speed 191.0 mph
0 - 30 mph 1.7 seconds
0 - 60 mph 3.4 seconds
0 - 100 mph 5.7 seconds
0 - ¼ mile 9.4 seconds
Lateral Acceleration est 1.70g
CLK-GTR SPEC
Dimensions
WheelBase - 2670 mm
Length - 4854 mm
Height - 1102 mm
Width - 1951 mm
Weight 1000 kg
Front / Rear Track
Front - 1600 mm
Rear 1600 mm
ENGINE
Configuration V12
Bore - 89.0 mm
Stroke - 80.2 mm
Compression Ratio
12.0:1
Redline 7800 rpm
TRANSMISSION
Type 6-Speed Manual
Final Drive 2.88:1
CHASSIS
Tire Sizes
F 280/35R-18
R 330/40R-18
Brake Size
F 381 mm / 15.0 in
R 356 mm / 14.0 in
PERFORMANCE
Top Speed 191.0 mph
MidnightBlueNeon
9
06-26-2006 01:09 AM
