Other Post discussion on all other models not listed above here.
1983 300SD Sunroof Help!
Old Feb 11, 2006 | 01:30 PM
Big Thib's Avatar
Default 1983 300SD Sunroof Help!
My g/f's dad has an 83 300SD and his sunroof is stuck open. Is there anyway to manually close it? Please help, it's been raining a lot and it's wide open.
Old Feb 24, 2006 | 01:06 PM
BlackWolf's Avatar
Default RE: 1983 300SD Sunroof Help!
Sorry, I just seen this post. Haven't been in the other model section in a while.
There is a manuel **** in the trunk usually found on the driver side (opposite side then the door to the gas tank cap.). Pull back the carpet on that side and it's a white (or might be another color for that year.) ****. I forget the shape of the hole or tool you will need to turn the **** because I haven't looked at mine in a while and my Mercedes is not with me right now.
Old Feb 25, 2006 | 01:06 PM
Big Thib's Avatar
Thank You very much, as soon as i get to his house, I'm gonna see if i can locate it and get it closed. thanks again
Old Feb 25, 2006 | 08:02 PM
duxdevil's Avatar
Thib, not to be mean but jsut as a suggestion you may want to read through the manual completely for it, or have him do so. There are countless little neat tricks tips features and pointers throughout almost every diesel Benz that you can only discover by reading about. For instance, it is likely that that model has a built in engine block heater- you jsut need to find teh cord and figure out how to use it.
touche
travis
mlmrk
Sep 4, 2014 07:00 PM
sfk
Dec 8, 2007 07:25 PM
CollectiveSoul
Feb 18, 2007 03:54 PM
mespe
Sep 14, 2005 10:37 PM
sammy
Oct 7, 2004 07:42 PM
