clutch pedal won't work c230 2003 w203
My 2003 c230 kompressor manual transmission clutch pedal was "soft" and had problems shifting gears / choppy. Then clutch pedal finally stopped bouncing back from depressed for gear engage/change and remains stuck to floor .Can't shift gears as pedal inoperative to disengage clutch to shift gears
VIN WDBRN40J93A417011 |
Hello and welcome to the forum! Take a look at the link below, it should help you troubleshoot.
https://www.pelicanparts.com/techart...d_Resevoir.htm |
Thanks. But the brakes were / are working fine Its just the clutch pedal thats inoperative.
Thus, the brakes Master Cylinder seems fine Could be some other cylinder ? |
