-   Mercedes SLK Class (https://mercedesforum.com/forum/mercedes-slk-class-14/)
-   -   water in headlights (https://mercedesforum.com/forum/mercedes-slk-class-14/water-headlights-17645/)
doctort Jan 26, 2007 05:45 PM
water in headlights
When I wash my SLK320, it gets water inside the headlights. Any quick do-it-yourself fix for this?
bazzle Jan 27, 2007 01:25 AM
RE: water in headlights
Front lens leaks around edges. remove light, clip off lens and clean the foam rubber gasket.
Bazzle
doctort Jan 27, 2007 02:00 AM
Thanks for the info Bazzle. I'm an engineer and pretty good with tools. Is there any special trick to this I should know before I try it or is it pretty straight forward?
BikerDrew Jan 27, 2007 09:44 PM
There is a special clip holding the lamp assy to the car body at the bottom. The clip slides. Otherwise, screws hold the assy to the car.I would use a little sealant on the gasket when you reassemble the lamp. Hope this helps.
doctort Jan 27, 2007 09:50 PM
Thanks. Sounds like something I could do. Sure do appreciate the help.
bazzle Jan 29, 2007 07:43 AM
You will need to pop out the indicator to remove one of the screws. Push screwdriver down hole behind ind under hood to open catch.
Bazzle
doctort Jan 29, 2007 09:32 AM
Thanks Bazzle!
