Slk 320 battery warning light
Old Jun 5, 2008 | 02:51 PM
paulwith's Avatar
Default Slk 320 battery warning light
Hi,[/align]The battery warning light has just come on with the engine running.The drive belt is fine.Is there a simple test for the alternator,can it be reconditioned or swapped, if so can you advise anywhere in Greater Manchester/ Cheshire?[/align]It's a 2001 SLK 320[/align]Thanks.[/align]Ps I don't suppose it's just a case of replacement bushes!?[/align]
Old Jun 6, 2008 | 05:47 AM
bazzle's Avatar
Default RE: Slk 320 battery warning light
Normally brushes. About $20 a set, replace under vehicle.
Put a voltmeter across batt, start and it should go to about 13.8 volts +
Bazzle
Old Jun 10, 2008 | 11:27 AM
paulwith's Avatar
Thanks Bazzle, it was the voltage regulator, brushes were fine. replaced for £40.Alternator needs to be removed to fit.
GregInJrsy
Jan 11, 2018 11:35 AM
manli99@yahoo.com
Jul 14, 2011 02:34 AM
04c230k
Nov 24, 2010 09:13 AM
mercedesgirl2003
May 11, 2009 11:34 AM
poormishi
Oct 20, 2007 08:02 PM
