Slk 230,
Hi there, I have an SLK 230 Kompressor 2001 model, the window wipers engine does not seem to be working, is there anything you can advise? The water is not coming through and it does not seem that the mechanism pushing the water through is functioning.
you might have the pump problem. Test to see if you have current at the pump. If you do, replace the pump
