silicone lubricant for gaskets
As a newbie I'd like to keep my windshield/top gaskets in good shape. Have read on here that silicone lubricants work, but I cannot find anything that seems oily enough. Just sprays. Any advice on where to find a good product?
Thanks, BB in Florida, proud new owner SLK 230 1999 30k miles |
RE: silicone lubricant for gaskets
Spray a rag and then wipe the seals.
The absolute best stuff for this application is called Krytox made by Dupont. Look it up on Google. Operating range is something like -200C to +200C. Should suffice
Its used by most major manufacturers to overcome squeaks. Its mega expensive but once applied lasts forever. You just can't wipe it off! Usually applied from a small bottle with spong applicator but has recently become available in a spray can. Not sure where its sold in the USA but its made there. |
i thougth that silicone craked rubber in time making the problem worse then the medicine
Does Krytox® contain silicone?
No. Krytox is a perflouropolyester like PTFE and is inert and designed to be compatible with plastics. I therefore don't think it has silicon in it. I did get the temp range wrong however -135 to +650 deg F. Go view: http://www.dupont.com/lubricants/en/...utomobile.html USA contact number is on Frequently Asked Questions page. Stuart |
I've never heard of that. Of course I don't know everything, so how can an oily substance that keeps rubber soft crack it?
I think cracks may appear if you over soak the seals and then let them collect enough dirt over a long period without further silicone treatments or cleanings. Then as you keep mashing the seal in a door, for example, the dirt is an abrasive that dries and deteriorates the seal. |
