Resetting Check Engine Light
Old Feb 21, 2007 | 04:11 PM
Soccerdog6's Avatar
Default Resetting Check Engine Light
O2 sensor failure - replaced it. Does the light have to be reset by a technician? Tired of driving around with the damn thing on.
Old Feb 22, 2007 | 03:16 AM
snanceki's Avatar
Default RE: Resetting Check Engine Light
Sure it was the O2 sensor at fault? Why do you think it was the O2 sensor?
What was the code?
Should reset after a few cycles dependent upon age of vehicle etc.
Recheck what codes are showing.
Reset can also be accomplished with a simple scan tool at the time the codes are read.
Stuart
Old Feb 22, 2007 | 09:22 AM
Soccerdog6's Avatar
Thanks for the info. The fault code was for the forward O2 sensor. I will have it checked again.
Old Mar 4, 2007 | 05:42 PM
buellwinkle's Avatar
Disconnect the battery for 30 minutes, that will clear codes. Just make sure you have your radio code handy.
nolen01
May 7, 2015 05:58 PM
fltrplntman
Jun 1, 2009 01:18 PM
solarant
Dec 27, 2007 11:34 AM
