Replacing Cluter light-bulb problem!!
Old Apr 9, 2006 | 10:51 PM
PanzerKlyde's Avatar
Default Replacing Cluter light-bulb problem!!
Hello Again Sleepwalker,
How have you been doing, lately.
I have a 2001 SLK-320 Sport. One of the light-bulbs in my cluster went out (speedometer), and I'm having a hard time getting to it. I'd removed all possible screws and bolts at the driver-seat's legs area, but the darn thing still can not be moved. What do I need to do to get behind the cluster area..........to change one stinking light-bulb. Please help.
Many thanks in advance.
P.
Old Apr 10, 2006 | 10:10 AM
bazzle's Avatar
Default RE: Replacing Cluter light-bulb problem!!
Bugger Sleepwalker... he's asleep. Try Bazzle instead.
Actually they are not stinking bulbs[8D]
Answer here
http://www.mbslk.com/files/artikel/l...instrument.pdf
Bazzle
Old Apr 12, 2006 | 03:17 PM
Hi Bazzle.....
I will certainly am accept your offer . However, the web address that you'd attached does not work...I did try http://www.mbslk.com alone, and I can not understand a thing in that website....they were in German...hihihihihi. HELP.
Many thank
Old Apr 12, 2006 | 10:51 PM
sleepwalker's Avatar
it works on me. only a bit slow since it's in pdf format.
very nice instructions.
i will link it.
Old Apr 14, 2006 | 01:00 AM
bazzle's Avatar
ORIGINAL: PanzerKlyde
Hi Bazzle.....
Many thank
Try again... works for everyone else.
Just look at the pix. Open ,main site into a translator if you wish. http://babelfish.altavista.com/babelfish/tr
Bazzle
Old Apr 14, 2006 | 06:12 PM
Thank you, both.....Bazzle and Sleepwalker !!
I was able to access that website after all. I didn't have the correct software to open it at the begining.....
I could have not done it without your help. Many Thanks...again.
Attn: Sleepwalker
Awhile back, I querried you about the hissing noise problem from the pasenger's leg area.....and it was the switch over valve that was making that noise as you said. I'd purchase a new piece from the dealer in my area and replaced it. However, it still making the same anoying sound. But if I toggle the ac-fan switch from low to high, it will stop, only to hiss again in about 30 seconds or less. Currently, I have the unit unplugged.......and enjoy the outside air/exhaust fume from other cars on the road. Are there any other way or how to correct this problem ?.....Thanks.
Peos66
Jan 15, 2016 09:40 AM
ijdetoro
Feb 26, 2010 01:15 PM
Mistermax808
Oct 2, 2007 02:52 AM
PanzerKlyde
Oct 13, 2006 05:42 AM
MazdaCaddi
Mar 17, 2006 10:35 PM
