Power seat relay
Power seat relay
I need some help here. I have a 2001 SLK320, and I need to replace the power seat relay. The problem is I know the general location (under the dash left of the steering column). Can anyone tell me and even show me exactly where this relay is?
[IMG]local://upfiles/35391/5A8E55C7847842C6849347BD8CE89F8C.jpg[/IMG]
i finally found that seat adjustment relay on my 2002 slk320,and it did fix the intermitten problem.it is under the dash just to the right of the head lamp on/off switch.you need to remove the lower panel under the dash,actually 2 panels.this panel actually splits at the seam under the steering wheel and vent/light switch.be careful because there are alot of hidden screws,be gentil.remove the side panel on the dash between the door and dash.1 screw in the vent and a few under the dash.let me know how it goes or if you need any more info.
teo977
04-14-2004 10:00 PM
