More Horse Power for SLK-230
Old Jul 14, 2007 | 10:20 PM
mercedesman's Avatar
Default More Horse Power for SLK-230
Hi everyone. Does anyone know a good source for cold air intake? I am looking at putting one of these bad boys in my SLK-230 2000 but I am confused because there are 2 different intakes on the passengers side and the drivers there is another pipe going from the throttle body down toward the ground. Also, does anyone know any other ways to add great horse power. I have already added a flowmaster cat back exhaust. I heard if you move the MAS sensor you can get better horse power, but where do you move it to? Thanks
Old Jul 15, 2007 | 03:31 AM
bazzle's Avatar
Default RE: More Horse Power for SLK-230
Depends on the year if moving maf required, pre 2000 normally to reduse a flat spot.
Only proven way to get more from this engine is a larger crank pulley.
Cold air, chips and exhaust dont do much.
If pre 2000 then maf relocate kit, plugs and fpr req.
All info here www.aspracing.com
Bazzle
Bazzle
Bazzle
Old Jul 15, 2007 | 12:53 PM
Hello, I have a 2000 SLK Mercedes Benz Special addition model. I hope this helps. Where can I get the pulley? Thanks
Old Jul 15, 2007 | 01:05 PM
Hello, I understand now that you can get a pulley for the benz, but how much horse power would I be getting? I added a standard K&N filter in the stock air box and that seemed to add some horse power. I would like to switch to cold air because from my understanding it adds even more. It just looks confusing to hook up the cold air. What do you think about the ECU being reprogrammed or chipped? Also, check out this website. I found a cold air with this turbo looking device buit in. Do you think this adds horse power? http://www.myhotmercedes.com/mercede...Charger/534467
Also, anyone know where to get a aftermarket grill for this car?
Old Jul 16, 2007 | 07:08 AM
bazzle's Avatar
Mercedesman. You need to post on with those questions, many many times answered. SEarch will help.
As stated in my prev post for pulley.
Bazzle
Old Aug 5, 2007 | 08:09 PM
pmajet's Avatar
What is a MAF relocation kit?
Old Aug 6, 2007 | 12:39 AM
bazzle's Avatar
ORIGINAL: pmajet
Moves MAF from next to rad to same spot as later SLK230's
Bazzle
Old Nov 14, 2010 | 05:39 AM
dig66's Avatar
a diode on the map sensor
rpleasant
Mar 31, 2013 11:06 AM
mbgt
Aug 5, 2011 11:19 AM
freejo1
Mar 16, 2008 09:32 AM
pompeysteve
Jun 30, 2007 05:55 AM
millsy000
Sep 17, 2006 09:50 PM
