Miles between oil changes for SLK230, 01
I just got my car. It didn't even come with an owners manuel...so I think I will be on here checking out everything I possibly can. My car is currently in the shop right now because the catalytic converters broke apart inside...so they're being replaced. I know they're changing the oil with Mobil 1 Synthetic. So I can go 6,000 miles without an oil change. I'm curious about the filter too. Good question BikerDrew!
Glove box manual on here. http://www.virgeweb.com/rage2/slk_r170_manual.zip
resetting service display here http://eerola.home.comcast.net/auto/MBSLK230Kdiy.html
SLK how too.. http://www.slk32.com/pages/gotopages/howto.html
Bazzle
BMW's and Mercedes dealerships both put in mobil 1 synthetic oil. Not saying it is the best synthetic, but it has been proven that with oil changes every 15,000 miles do not cause significant problems. I would change it every 10,000, just a personal opinion. I would use mobil 1 synthetic though because 5 quart containers are only $25 at wallmart.
In my opinion, you know when you are not changing the oil often enough when after an oil change you have a power increase. You should change the oil before it gets too dirty, and if your car performs better after an oil change, then the old oil was hindering the cars performance, ie... not good.
