K40 relay R170
K40 relay R170
This is a common issue on these vehicles . Dry joint on the fuel pump relay. Resoldering fixes.
This module gives a few different problems, the main one being fuel pump probs.
It is worth opening the computer box and pulling it out for a look.
It is a multi relay pcb. Some of the sldered joints suffer from cracking and dry joints.
A simple sesolder can fiw or prevent a few frustrating issues.
K40 Relay - Right hand drive
LHD opposite
Remove neg batt term
Remove computer lid
Unclip holding tang and lift up module
Pull off connectors
Open case of module
Inspect soldered joints for cracks, overheating, dry joint etc
An eyeglass may help (top left hand group of three)
Remove old solder and resolder with new
Replace module
Push on connectors
Remove and replace 40A fuse to wipe the contacts.
Replacelid
Replace neg batt terminal.
Start car
Redo radio code if required.
Bazzle
LHD opposite
Remove computer lid
Pull off connectors
Open case of module
Replace module
Push on connectors
Replacelid
Start car
Bazzle
RE: K40 relay R170
Thanks for the demo Bazzle.
Stuart and I followed it to the letter on Sunday morning.
Once inspected and found to be sound we refitted it and the car started.. always a bonus!
However, as all the joints were found to be good, it seems it's time to look at the CPS.
Cheers, Si
neunan
04-17-2005 10:09 AM
