HVAC Problem?
Old Apr 3, 2007 | 01:14 PM
BillP2R's Avatar
Default HVAC Problem?
Hope you'll excuse a Crossfire owner for jumping in here, but I've a question about a problem with the HVAC system's blower housing (which I think the Crossfire and the first generation SLK share).
While running down a problem in which my HVAC system was stuck in the re-circulat position, I found that the return spring which is meant to return the air source flap to the fresh air position was no longer anchored to the blower housing. It appears that the anchor point has broken off of the blower housing.
Unfortunately, it would be necessary to remove the heater core and A/C evaporator to get to the area where the spring should be anchored and I'm not equipped to properly discharge the A/C system. For now, I've simply disconnected the vacuum valve which pulls the flap into the re-circulation position so as to keep the system in the fresh air mode.
Now for my question: I'm aware of at least one other Crossfire that has experience this failure and I'm wondering if it is prevalent with first generation SLKs also?
Anyone?
------------------- Bill
Old Apr 4, 2007 | 10:16 PM
bazzle's Avatar
Default RE: HVAC Problem?
Gooday
Its not a problem Ive heard about. Good luck with the future fix. The changeover valve is also an item that has failed on a few SLKs R170.
People normally just block off the line
Bazzle
ourson
Oct 13, 2007 10:49 AM
C240RedGirl
Dec 14, 2006 07:23 PM
86420SEL
Jan 9, 2006 10:57 PM
swells
May 11, 2005 11:26 PM
cam69ss
Nov 12, 2004 08:11 AM
