How do you adjust the window up stop 98 SLK
My post is to find out how to adjust the windows from raising to high.Currently they raise to high and when you close the door the window lays on the outside of the roof window seal
RE: How do you adjust the window up stop 98 SLK
door panel must come off then move window down until you see the screws at the glass. there are screws also under the door at the bottom of the door covered by little black rubber covers these also adjust window. you must move window all the way down to access the screws for that. i think they are small torx.
