How to change spark plug wires
Old 12-18-2012, 03:32 PM
Default How to change spark plug wires
Hi, I have found many posts on changing plugs but I cant find how to change the spark plug wires on my 2003 SLK230. I have a misfire on plug 2. I changed all 4 plugs, switched coils but it still showed misfire on #2. I bought 4 boots and changed only #2 and realized that this would not help. Can anyone give me advise on how to change the wires that all seem to be black taped and disappear under a metal cover. Any advice would be appreciated. I dont want to take to garage now that I have done much work myself. thanks
docjay
Old 12-20-2012, 12:52 PM
Really? 42 view this post and no one knows how to change plug wire? Where's my ignition gurus?
docjay
Old 12-27-2012, 12:09 PM
Old 12-30-2012, 02:25 AM
I have some confusion on this, assuming all slk230s are the same from 98 to 03. the only two spark plug wires are under the red cover and go to 1 and 3 spark plugs off the coil packs and coil packs go directly to 2 and 4 plugs. Which other wires might you be referring to?
Old 01-02-2013, 11:03 AM
My 2003 SLK 230 has 4 coils above 4 plugs with 4 wires running from each coil down to a wire harness that is covered by a metal top plate. this sounds different than what you are describing. I also so only pictures of 2 coils on threads to change plugs. This is differnt than most.
jay
Old 01-03-2013, 05:11 AM
so there is a difference on later model 170s. Mine is a 98 and has 2 coils. I guess they started using the four coils in 2000. Learn something new everyday, thanks. if you've replaced everthing and there's not a short or a bad connection, like at the control module. there's not much between the coil packs and the control module but wire. you might want to have it diagnosed to be sure or maybe you might want to get the CarMD reader.
Old 01-04-2013, 09:58 PM
maybe a clogged or defective injector?
kzukowski
05-02-2011 09:44 PM
klmanjaro
08-24-2010 05:40 PM
blair771999
03-23-2010 08:46 AM
ala59654
10-11-2007 01:28 PM
fay3131
09-04-2005 11:27 PM
Quick Reply: How to change spark plug wires
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
