help. wipers gone crazy!
Old Mar 4, 2006 | 07:33 PM
  #11
shak's Avatar
Default RE: help. wipers gone crazy!
Hey there. I have taken the wiper motor out and inspected the connectors, the 4 wires going from control module to wiper motor.
The wiper motor has a switch in it that detects the correct position for the wipers to PARK. This switch/contact supplies power to the motor independent of the column switch. The contacts on these switches can "get dirty" (arc etc) and can therefore stick together causing the wipers to continue running even with power off.
Are the contacts the 4 wires? The wires are connected to the bottom of the wiper motor with some sort of glue-gun looking substance. I opened the bottor metal cover and inspedted the wires. There were 3 resistors connected there and i cleaned some grease that got there. Unfortunately, the problem is still there.
Now, do I need to take the actual motor cone out too? I think that thing just has the mechanical gears and stuff.
Old Mar 5, 2006 | 04:32 AM
  #12
snanceki's Avatar
Without the component in front of me I really can't help much more. You need to trace where the four wires go. OK there are some resistors. (surprise No.1) but there should be some form of switch which can sense the position of the output spindle, not the motor shaft which will rotate many times per sweep of the screen.
If there is no such device to sense position then MB must sense position using current waveform which will all be in software in the control unit in which case I guess you are back to the original diagnosis from the dealer, the control unit.
If indeed the sensing is done by software it is still possible that the wiper motor itself is on the way out and giving a completly incorrect waveform for the control module to analyse. I repeat that control modules (except in very early life) don't usually go wrong unless the car has been jump started incorrectly etc.
No need to take the motor itself apart since this is working. There will be wires connecting to the motor rotor through brushes however.
When you put it back together make sure the unit is watertight. The gung you refer to will likely be a silicon RTV sealant like you use around the bath tub to make the access point for the wires watertight.
Let us know what happens since this may help others. Stuart
Old Mar 14, 2006 | 02:40 AM
  #13
shak's Avatar
Still here. A quick question, what ius the Mercedes part # for combination control module? Is it n 10-3? I am trying to find a used one. I cant see myself giving them $800 for a stupid module.
Thaks.
Old Mar 15, 2006 | 03:00 PM
  #14
shak's Avatar
bump.
Old Mar 16, 2006 | 02:08 PM
  #15
shak's Avatar
Hey there. I called the dealer today to get the part number and they wont give it out. He claims it is their policy. Did anyone heard this crap from any other dealer. This one is located in Jax fl, Brumos motors.
Is there a online catalog I can use to locate the part #.
Old Mar 16, 2006 | 03:56 PM
  #16
bazzle's Avatar
http://www.mercedesshopen.com/Shop/I...nguage=LangEng
Try here for a 2nd hand part and price.
Bazzle
Old Mar 16, 2006 | 09:30 PM
  #17
sleepwalker's Avatar
A170 820 09 26
Old Mar 17, 2006 | 02:00 AM
  #18
shak's Avatar
Thank You.
vampyres4ever
Jan 8, 2009 07:26 AM
95ee320
Dec 11, 2006 10:19 PM
SpecialK
Dec 4, 2006 01:05 PM
engenuity
Mar 12, 2004 03:21 AM
