Help! SLK 350 Transmission
Old May 15, 2008 | 11:57 AM
bk64's Avatar
Default Help! SLK 350 Transmission
Hi!
I bought 2005 SLK-350 (48K miles) CPO last week from Benz dealer. I have a concern about Transmission. When the car goes below 20 miles speed (no gas/ no brake) the transmission engages and try to stop the car. A grinding noise also comes at the same time.
My other Japanese car rolls over smoothley and eventually comes to a stop in the similar situation. This is my first Benz + Sports car and I want to make sure that this car does not have any transmission or other issue that I need to worry about.
BTW, the car runs great otherwise and accelarates fine both in automatioc and manual mode, the issue is only at slow speed.
Thanks for your response.
BK.
Old May 17, 2008 | 03:26 AM
bazzle's Avatar
Default RE: Help! SLK 350 Transmission
Not sure what you mean by a grinding noise but they can change down into 1st gear when you slow pullinmg the car up abruptly. A trans readaption may help.
I would go back ans ask the dealer what they think..
Bazzle
Old May 18, 2008 | 07:12 AM
bk64's Avatar
Thanks for your response, Bazzle.
I did take the car to dealer and they said downshifting is OK, however, they saidnoise is coming from tyre. I am worried about this noiseand transmission engaging to slow down the car at lower spped (No gas/No brake).
What is readaption, is it reprogramming of Trans?
BK
Old May 24, 2008 | 06:10 AM
bazzle's Avatar
Yes, dealer will know..
Bazzle
Old May 24, 2008 | 04:45 PM
NAZ's Avatar
NAZ
in your case it requires soft ware adption is your box 7speed?or ???????????if its 7 speed they do need a lot of soft ware programing only once and it should be fine....
DCCLK350
Mar 11, 2009 09:41 AM
E9N20
Apr 2, 2007 03:48 PM
GBMC Raffle
Aug 27, 2006 03:11 PM
endo
Dec 24, 2004 03:37 AM
E8N14
Dec 20, 2004 07:48 AM
