HELP! No acceleration
Old Dec 21, 2008 | 12:30 PM
xousabe's Avatar
Default HELP! No acceleration
A couple of weeks ago I noticed that my car had an acceleration lag of about three seconds when I would hit the gas. Now when I hit the gas the car has no acceleration! The car starts fine and has no rough idle but when I hit the gas pedal, the car does nothing. I can only go three miles an hour! I need my car so I can get to work. Any help would be appreciated!
Sincerely,
Abel
Old Dec 21, 2008 | 10:52 PM
snanceki's Avatar
Default RE: HELP! No acceleration
You don't mention model / year / mileage etc!
Is the CEL Check Engine Light ON?
If so its likely in "Limp Home".
Subject to above it is possible that the EA Electronic Accelerator system (fly by wire) has failed. The accelerator pedal potentiometer wears out (mechanical) or water gets into the servo motor attached to the throttle butterfly. The latter fits your symptoms bette.
Get the DTC Diagnostic Codes read on the car. Any set?
Stuart
root_foo
Jun 6, 2014 12:38 PM
JosephAuto
Sep 21, 2010 01:31 PM
sideshow76
Jul 22, 2008 05:39 PM
teevra
Jul 19, 2004 02:56 PM
daff12
Jul 6, 2004 04:56 PM
