Code readings & cam adj noise.
Hi Guys, I have been very impressed with the answers your getting on this site. I am in the UK (Wales) and have just bought a 2003 SLK200K in black! I also bought a code reader as a lot of the troubles you have I have!! Code reading PO 131 is the front O2 sensor, but what is actually wrong and can it be cleaned? I had a rattling noise at low revs (1500-2000) and learnt that it was the cam adjuster "kicking" in & out. But it was noisy so I pulled the plug on the cam magnet, now no noise, but what do you think about that? The code for this is showing PO 010. Look forward to any advice. Cheers.
The O2 sensor's can not be cleaned, once they go its time to replace them. Not sure if any harm will come from having the cam adj. mag. unplugged. Its there for a reason i would just replace it, the are cheap and simple to replace.
Originally Posted by livefreeordie
(Post 123828)
there's most likely no damage being done if the "magnet" is unplugged. it operates so that the cam adjuster on the camshaft can adjust exhaust timing for better efficiency during certain rpms.
Originally Posted by tech_45
(Post 124491)
Hi and thanks for your reply. It is as I expected, having read loads, but it is nice to have someone else confirm it! Car runs well so I'm leaving it. I've looked into replacing the cam adjuster, but apparently its about £500 plus labour!! So theres really no contest. Cheers. Owen. |
Same rattling problem :(
I know this is an old post now, however, I have recently purchased a 2003 SLK200K for my wife and she is experiencing the same rattling noise at low revs (1500-2000). It has also been confirmed by Mercedes to be the cam adjuster/magnet and that the noise is normal (can't believe they said such an annoying noise is normal!). I see you mentioned that disconnecting the magnet resulted in the noise stopping - has anyone managed to find out whether disconnecting the magnet can cause any other damage? I would love to find a solution to stop the noise, even if it means the performance/fuel efficiency is reduced slightly. Any help is much appreciated! John |
There is a recall here in the USA for this part, not sure about other parts of the world.
