camber adjustments rear SLK320
Hi. My question concerns - camber adjustments rear SLK320. The 05 C classs sport rims and tires are really a nice touch - moving from 16" to 17" wheels. The overall diameters of these tires fall within several mm's of originals. The width moved up 1/2 " in the front and the rear. Fitment after putting a Eibach Prokit (1.2" drop)on is right on too. The rear chamber is very slighty negative..... what can be done to bring that into specs?..... are there pads (the ones over the springs) that maybe able to be bought in differnet sizes - or will that help at all. The reason I am asking has more to do with the fact that AMG upgrades to the SLK have the same wheel/tire specs (within mm's on the offset) as the C class sport and I see no negative chamber on those SLK's. I see this as a very minor issue but.....Please advise. Thank you, WW
