Better scanner
I need better scanner data than the garden variety Innova or Accutron (I have both). I want to spend under $200 I was hot on the trail of the icarsoft MBii, Launch X431 VIII, Carly app etc but one by one as I finally find the list of vehicles that these scanner apply to my R170 (2001 SLK320) is not on the list, only the R171 and R172. Whats the most scanner I can buy for under $200 that applies to my vehicle. I DIY everything and was in the electronics profession, my current problem is a P0600 serial communication error.
Thanks, George |
Hi George - take a look at the link below to the Schwaben tool. We highly recommend it, please let us know if you have any questions.
Schwaben Pro Scan Tool for Mercedes Benz |
Never seen this tool. Thanks.
Originally Posted by GeorgeG
(Post 175459)
P0600 Code?
Hey George, thanks for your post. Please share what you find with your P0600 code ... I have the same code and it goes into limp mode.
Originally Posted by Esrog
(Post 175492)
What causes the P0600 code? Failing ECU or the ECU has failed Low battery voltage ECU wiring harness open, short or poor electrical connection What are the symptoms of the P0600 code? The Check Engine Light will be illuminated ABS and traction control system lights may illuminate The vehicle runs poorly Has trouble staying running Engine may not start Transmission may not shift properly |
(Post 175410)
Car enthusiasts looking for a “better scanner” often demand clarity and precision. The https://wellness-app.com/calculator/fasting-calculator/ fasting clock gives similar clarity for your eating and fasting schedule. Input your desired fasting duration and preferred meal times, and the tool outputs a structured plan. Just as a dependable scanner reads engine data to guide maintenance, a fasting clock maps your body’s fuel windows to support consistency and better metabolic results. Thanks, George |
| All times are GMT -5. The time now is 10:33 AM. |
