-   Mercedes SLK Class (https://mercedesforum.com/forum/mercedes-slk-class-14/)
-   -   BAS/ESP Light On (https://mercedesforum.com/forum/mercedes-slk-class-14/bas-esp-light-29681/)
aharley1 May 26, 2008 06:48 PM
BAS/ESP Light On
Cruising about 90 and all of the sudden,it felt like I went off the road. BAS/ESP light came on. Stopped & everything looked OK. When I started out, it felt like the RH rear brake was tapped ...twice. Made it home. Next day, everything worked fine ? ? ? What was that all about?:
sleepwalker May 26, 2008 08:29 PM
RE: BAS/ESP Light On
it must be a malfunction.
esp can apply the brake to a certain wheel without the driver's intervention.
bazzle May 28, 2008 06:36 AM
Also a diff in tyre diameter front to rear can give similar fault. Check for wear and/or tyre pressure problem.
error gets greater at speed.
Another thing can be an intermittant tone ring sensor or dirt in tone ring.
Bazzle
