BAS/ASR Light on
Old Sep 5, 2006 | 12:33 AM
coolhuh's Avatar
Default BAS/ASR Light on
I have a 1999 SLK230 and the BAS/ASR warning light comes on every once in a while. I will be driving around and the warning light will come on, I do not notice anything wrong after it comes on. If I stop somewhere and turn the car off for a while the light resets itself and later it will randomly come on. Anyone now why this is happening.
Old Sep 5, 2006 | 04:34 AM
snanceki's Avatar
Default RE: BAS/ASR Light on
BAS or ABS?
Suggest Brake light switch. 2 circuits. 1 operates the brake lights (Normally open), the other the ABS (Normally closed).
If the ABS is out it turns off the ASR.
Old Sep 5, 2006 | 06:59 AM
bazzle's Avatar
ASR Traction control, wet road ??
Bazzle
Old Sep 5, 2006 | 03:30 PM
snanceki's Avatar
Good point Bazzle.
Was it the ASR operation light (yellow triangle) which might be linked to a wet road or the ASR malfunction light that illuminated?
I assumed the ASR/ABS malfunction lights. Correct?
Stuart.
Old Sep 5, 2006 | 05:01 PM
coolhuh's Avatar
It is in the warning lights and shows up as BAS on top and ASR under it. They come on at the same time and while they are on I can not use the cruise control and the ASR switch does not work.
Old Sep 6, 2006 | 06:20 AM
bazzle's Avatar
Wheel sensor loose or dirty ring?
Bazzle
Old Sep 6, 2006 | 06:38 AM
snanceki's Avatar
Cruise is also linked to the brake switch circuits.
Stuart
Old Sep 6, 2006 | 10:36 AM
coolhuh's Avatar
Where would I find the wheel sensor? And would this cause both lights
Old Sep 6, 2006 | 05:36 PM
  #9
snanceki's Avatar
Wheel sensors are inserted into on the hub castings. They are accessed from the non wheel side of the hub. if you trace the electrical wiring from the vehicle body to the hub this will lead you to the sensor. One of these leads is for pad wear warning. The other is the wheel sensor lead.
The interrupter ring (part of the sensing system is part of the driveshaft/hub assemblies and can get clogged with brake dust and general grot.
These devices send a speed signal to the common data network and impact all the systems that you have trouble with.
However why not eliminate the brake switch first.
Do your brake lights work?
Is your car automatic and if so can you get it out of PARK?
If Yes and Yes then this increases the chances that your problem is a speed sensor.
Stuart
Old Sep 6, 2006 | 08:56 PM
  #10
coolhuh's Avatar
snanceki,
My brake lights work.
I have an automatic and it comes out of park.
Would the speed sensor be the cause of the BAS/ASR light. Are these seperate issues the BAS and ASR. They always come on at the same time.
Thanks,
Jeff
