Another BAS/ESP Problem
Old May 4, 2005 | 02:03 PM
Soccerdog6's Avatar
Default Another BAS/ESP Problem
I too am now getting the BAS/ESP light as soon as I touch my brake pedal upon starting. I have read in past posts that it might be fixed with adjustment of the brake switch. OK, where is it and how adjusted? Any other ideas from those of you who are well educated in this problem?
2001 SLK 230.
Thank you in advance!
Old May 4, 2005 | 02:39 PM
sleepwalker's Avatar
Default RE: Another BAS/ESP Problem
on the brake pedal bracket
pull it up to reset
Old May 4, 2005 | 02:59 PM
Soccerdog6's Avatar
Thanks!! I'll try it after I get off work.
Old May 9, 2005 | 12:33 PM
Soccerdog6's Avatar
Sleepwalker,
OK, I tried your fix and found the switch to be fixed in place. I can take it out but no adjustment to its positioning or with the contact point on the brake pedal extension is possible.
I hope I am not completely retarded in what you were telling me to do. I am mechanically inclined but unable to find any way to resolve this problem. Any help possible, THANKS!
Old May 10, 2005 | 12:04 AM
you need a guide. here it is>>>>>>>>
[IMG]local://upfiles/1/19DDC2D2E3B34280A8619D5214A14774.jpg[/IMG]
Old May 23, 2005 | 12:00 PM
Soccerdog6's Avatar
I finally got around to adjusting the switch. IT WORKED!!
Thanks a million, now my cruise control works.
Old May 24, 2005 | 03:15 AM
Old Jul 5, 2005 | 05:36 PM
Soccerdog6's Avatar
OK Sleepwalker,
Your fix worked great until now. The darn light comes on about 20% of the time when the brake is applied. There does not appear to be any common environmental conditions causing it, such as temperature, etc. Just comes on ever-so-often. Any ideas? Time to replace the stinking thing?
Old Jul 5, 2005 | 10:51 PM
  #9
time to read the fault code.
it can be a steering angle sensor, bas control module, or the brake lamp switch.
pvoul
Jan 1, 2008 09:09 PM
mbenz66
Dec 10, 2007 06:26 PM
nighttrain
Jun 21, 2007 08:17 PM
martino
Dec 19, 2006 09:17 PM
