AC 1/2 hot and 1/2 cold
Good Morning
I have a weird problem or at least weird to me. I have a 1998 SLK230. The AC blows cold on the passenger side but hot on the drivers side. Is there a simple fix or is it on the way to the shop? Thanks Pam |
my first guess and easiest to get at would be the heater control valves next to where you put in windshield cleaning fluid. might put a hose clamp on one or the other and see what happens. could be other things but that is the most common thing with that symptom.
Thanks I will try that. I had the AC topped off and that did not help.
Thank you Pam |
it sounds like the Duovalve,(heater valve) mentioned!
