1999 SLK 230 stalling
Bought a 1999 SLK 230 w/ 64K a couple of months ago. Ran fine for a couple of weeks and then it started stalling without warning. Speed, road conditions, driving activity (e.g., cornering, straight-away, breaking, etc.) irrelevant. While driving the car stalls -- attempt to restart and the engine will not turnover -- wait five to 10 minutes -- engine turns over and restarts -- drive another 10 or 15 minutes and car stalls -- and the cycle repeats. Took it into the MB dealer and they said they could not find anything wrong. Had a $400 tuneup completed just the same. Included R&R of fuel filter, PCV, air filter, etc. Car ran fine for about a month and today it began to stall again -- and the cycle is repeating itself. For the record, we have used nothing but premium gas in the car.
Any ideas from former or present-day 230 owners? Stymied in Pike Road, AL! Jim |
RE: 1999 SLK 230 stalling
Ignion switch / starter relay based on no crank?
Stuart |
snanceki
Having it towed in to the dealership today. Will be sure to mention this! Thanks! Jim |
I have a 2000 SLK 230 have had the same problem. I just replaced the K-40 relay. I am sure this was the problem. After I installed the new part I took apart the old circuit board. I found several cracked solder joints on the board. Hope this helps.
K40 open circuit / cracked joints is a common cause of such faults.
Stuart |
Stalling update -- dealership determined it was the crank positioning swith -- swapped out to the tune of $350 -- stalled the very next morning -- brought it back -- review of computer error codes NOW indicates to dealer it is the K40 -- they pulled the CPS and refunded me the cost for it and charged me only $37 for the additional labor -- we pick it up tomorrow -- will let you all know the score.
Thanks to all who responded! kayakbound |
You stated it didn't crank.
Wonder what codes they found originally? Sounds fishy to me especially since they refunded your money. Why on earth did they think it was a CPS when it wouldn't crank!! Stuart |
Picked the car up Friday morning [Nov. 10] after the K40 R&R. Wife drove it all weekend and today -- no stalling [yet]. Hopefully this positive trend will continue!
Again, thanks for all the input. Will always wonder had I not mentioned the K40 relay -- as pointed out on this thread on numerous occasions -- if the dealer would have spotted via the computer code. [Odd they never spotted it the first time!]. Regards to you all! Jim |
KAYAKBOUND How much did you end up paying at the mercedes dealer. How much did they charge for the K-40 relay? I bought mine online for $144.00 and it took about 5 to 10 minutes to install. Thanks
By the time it was all over [if it is] -- about $390! Wished I had known it was an easy R&R. Damned shame, eh!
Where is the switch located on the car, scrmnss? Just in case I have to deal with this again -- and in the meantime I can tell all the world. Jim |
| All times are GMT -5. The time now is 03:51 AM. |
