'01 slk 320 turns over but not fully starting
Old May 16, 2006 | 01:20 AM
stepmom89's Avatar
Default '01 slk 320 turns over but not fully starting
At random times, car will sound like as if it wants to turn over & almost sounds stuck in that mode, but will not start.
Any suggestions?
Old May 16, 2006 | 04:10 AM
sleepwalker's Avatar
Default RE: '01 slk 320 turns over but not fully starting
battery weak or bad contacts on battery cable.
Old May 20, 2006 | 06:57 PM
stepmom89's Avatar
Actually, it doesn't appear to be the battery. The car cranks fine when cold start, it's after being driven & the car is warm. The car has stalled out while idleling & sounds almost likes it's flooded.
Old May 20, 2006 | 10:16 PM
i cannot say that you got a leaking fuel injector... filling up the cylinder when you turn off the engine, and therefore cannot compress (or compression too high).
some tests must be done first.
gsm631
Jun 27, 2016 07:34 PM
Monica Fadden
Jun 19, 2013 10:40 AM
Monica Fadden
Jun 19, 2013 10:37 AM
jspskompressor
Nov 25, 2010 10:49 AM
mudsam
Aug 7, 2009 07:41 PM
