What do I have ?
Old Jul 21, 2005 | 07:36 PM
pbk's Avatar
pbk
Default What do I have ?
To Sleepwalker or anybody. I have a"86" 300SL. But do I have ABS brakes? What is the lever on the auto. trans marked E for econo or S for sport, but I don't feel any difference. Maybe you can help. VINWDB1070411A034923. Thanks
Old Aug 6, 2005 | 04:11 AM
MBZTech's Avatar
Default RE: What do I have ?
When the lever is on "E" than you should feel the trans slipping a little more. When its on "s" it should engadge a little harder. Those terms have now changed to "w" and "s" which stand for winter and summer modes.
Old Aug 6, 2005 | 07:25 AM
sleepwalker's Avatar
you have these:
VIN WDB1070411A034923
Model 300 SL
Chassis 1070411A034923
Engine 103982 12 000011
Transmission 722322 02 656887
Order 0 - 222 00180
Approx. year not defined
Lights BOSCH
Cab 00005
Dealer Wuppertal branch (222)
Interior leather brazil brown (273)
Paint
702 smoke silver metallic (с 01.01.1983)
Options
240 outside temperature indicator (с 01.03.1982)
second spare wheel (с 01.01.1964 по 28.02.1973)
256 rear axle with limited-slip differential (с 01.11.1965 по 30.11.1991)
280 trunk set, 3-piece (с 01.09.1964 по 31.08.1972)
steering wheel (400 mm dia.) and gearshift lever in leather trim; on W202 390 mm dia. (с 01.05.1984)
440 bumpers with guards, front and rear (с 01.10.1970 по 30.04.1974)
bumper with horn and rubber buffer front and rear (с 01.03.1964 по 30.09.1970)
tempomat (cruise control) (с 01.09.1975)
470 anti-lock braking system (abs) (с 01.06.1978 по 31.10.1993)
special export version 3 (с 01.12.1966 по 28.02.1968)
fan clutch (с 01.04.1970 по 30.11.1976)
506 outside rear view mirror, left, electrically adjustable and heated (с 01.07.1983 по 30.09.1983)
outside rear view mirrors, left and right (с 01.01.1963 по 31.07.1971)
outside rear view mirror, left and right, heated (electrically adjustable on the right) (l.h.d.) (с 01.10.1983 по 31.03.1989)
outside rear view mirror, right, convex, taxi export version
501 + 509 (с 01.08.1971 по 30.04.1974)
532 automatic antenna without radio set (с 01.01.1963)
543 exhaust-pipe cover trim (с 01.01.1963 по 28.02.1963)
seat adapter between the front seats, and halogen lamp unit (с 01.01.1967 по 31.12.1972)
sun visor with vanity mirror, illuminated, left and right (с 01.11.1978)
565 rear seats used on sl models (с 01.01.1963)
570 folding armrest front w202/210 stowage box front with armrest (с 01.04.1970)
front folding armrest w202 - housing at front with armrest
581 Thermoking air conditioner (с 01.04.1970 по 31.12.1972)
automatic climate control (с 01.01.1977)
592 wyellow foglamps (с 01.01.1963 по 31.10.1965)
heat-insulating glass, all-around, heated rear window pane (laminated glass), band filter
heat-insulating glass, side window panes (с 01.02.1967 по 31.01.1971)
green heat-insulating glass all round, heated rear window, laminated safety glass - tinted strip (с 01.01.1972)
610 bulb for main headlamp yellow (с 01.02.1963 по 31.10.1965)
headlamps and fog lamps and additional bright light with amber lenses (с 01.11.1965 по 31.03.1994)
halogen lamp unit, amber (с 01.04.1994)
629 version for France (с 01.04.1964 по 29.02.1988)
746 folding top fabric8023 dark brown (с 01.08.1972)
MBZTech was right because on Economy you start from 2nd gear and 1st gear on Standard.
however, you may also start from 1st gear in Economy mode during full throttle (kickdown switch actuated).
Old Aug 6, 2005 | 11:35 PM
pbk's Avatar
pbk
I really thank both of you, I allways learn so much on this forum.
prospeedauto
Jul 14, 2015 10:19 AM
amorring
Feb 5, 2011 06:15 AM
prospeedauto
Oct 6, 2008 03:38 PM
C280 wizard
Jan 27, 2005 02:44 AM
