SL ROLLBAR WARNING LIGHT
<TABLE id=INCREDIMAINTABLE cellSpacing=0 cellPadding=2 width="100%">
<T>
<TR>
<TD id=INCREDITEXTREGION style="FONT-SIZE: 12pt; CURSOR: auto; FONT-FAMILY: Arial" width="100%">
<DIV>All R129 owners can any body help me.</DIV>
<DIV>I have had my SL320 diagnosed by mercedes with no joy.</DIV>
<DIV>After a flat battery the roll bar warning light stays on all the time and the roll bar switch flashes </DIV>
<DIV>when roll bar is downand goes out when roll bar is up. Also the windows intermittently stop lowering when you open the door. </DIV>
<DIV>I have Tried synchronization with no luck. </DIV>
<DIV>If any body can help or email a diagram of where the control modules</DIV>
<DIV>are located that would be great</DIV>
<DIV>Thanks.</DIV>
<DIV>Dave Franklin (uk)</DIV></TD></TR></T></TABLE>
<T>
<TR>
<DIV>Thanks.</DIV>
I just purchased a 97 sl320 and I have the same problem that my roll bar light blinks with the rol bar down. I also had the batteries disconnected. I can't find a way to get the light to go off.</P>
I am new to this forum. Have you had any luck with your problem If so please advise.</P>
Thanks.</P>
I had the same problem with a '96. I believe it is caused by a fault code being set in the soft top controller. I know of no way to clear the code other than to take the car to a dealer or an independent who has a Mercedes Hand-Held Tester or equivalent diagnostic tool. My dealer spent about 5 minutes clearing my code and charged me $100. On a '95 or older car you can clear the code yourself.
MBGuy65
Jul 10, 2013 10:33 AM
MB-500SL
Feb 27, 2012 12:07 PM
