Shifter knob replacement
Old May 8, 2004 | 10:11 PM
Rich WNY's Avatar
Default Shifter **** replacement
Can anyone give me instruction on how to remove the shifter **** on my 1990 mercedes
500sl.???
Old May 13, 2004 | 10:44 PM
Lugnut's Avatar
Default RE: Shifter **** replacement
Well, it doesn't look like anyone is going to offer any help, so I'll tell you how I take mine off. Maybe yours is the same. If not, never mind.
There's a plastic emblem on the top of the ****. Pop it off using a small flat blade screwdriver and a rag being careful not to scratch, dent, or tear anything. You should see a hex key or torx nut. A few turns with the appropriate wrench and voila.
Old May 16, 2004 | 06:44 PM
bbs138's Avatar
remove c clip ..use long screw driver to pop out.to install put grease and plug in
best to buy 2 pcs. easy to break.....
ab4jy
May 23, 2014 02:38 PM
bsmith1
May 12, 2014 07:13 PM
bigjiun
Jan 22, 2007 01:23 AM
oOApEx
Sep 13, 2006 11:18 PM
neilbaud
Sep 17, 2004 09:53 AM
