just purchased '93 500SL
Old Nov 11, 2007 | 01:22 PM
anisrote's Avatar
Default just purchased '93 500SL
Its a sweet ride although it needs a lot of maintenance and repairs.
Since this is my first mercedes, I need some help with the dash buttons:
How do I turn off the AC?
How do I open the gas door?
How do I adjust the steering wheel?
Is there a way to disable/disconnect the passenger side airbag?
[IMG]local://upfiles/28043/EFB22BB85CFF4E03BD8E00ADD73158D3.jpg[/IMG]
Old Nov 11, 2007 | 03:48 PM
SunGuy62's Avatar
Default RE: just purchased '93 500SL
With the exception of disabling the airbag (why?), all of what you're looking for is in the owners manual. If you don't have one, you can download a copy at www.benzworld.org .(Free registration may be required) In the Roadsters Forum, 129/SL, you'll see a postingwith a'Sticky', in the first few on the page containing the topic, 'Download Owners Manual'. Open this thread, follow the instructions....you'll be good to go.
Bob
Old Nov 11, 2007 | 09:01 PM
winsteadi's Avatar
all of these questions can be answred by consulting the owners manual. with the exception of your last query, which i would not assist you on, unless you can give me a pretty good reason .
W
Old Nov 11, 2007 | 09:30 PM
anisrote's Avatar
I found and downloaded the owners manual. Thanks.
As far as the passenger side airbar: I would like to disconnect/disable it, so I can put in a rear-facing child car seat.
Airbags and car seats don't play well together.
Old Nov 11, 2007 | 10:22 PM
SunGuy62's Avatar
ORIGINAL: anisrote
And taking a broadside hit to the car without a side airbag won't do your child much good either. I suspect your insurance company would renig, and you'd likely be cited for reckless endangerment...should I continue or would you want to re-think better options.
Bob
Old Nov 11, 2007 | 11:38 PM
anisrote's Avatar
Its the passengerfront airbag that I want to disconnect.
This model car doesnt have "side impact" airbags so,the risk ofbeing broadsided is still there, be it the driver's or passenger's side.
Is therea way I can get a seat belt added to the back?
Old Nov 12, 2007 | 12:14 AM
anisrote's Avatar
Hi Bob (SunGuy62)
THanks for your post[sm=thanx.gif]
According to thethe NHTSA and IIHS (Insurance Institute for Highway Safety) [sm=proof.gif]
"If a driver does get a switch, it should be used to turn off the airbag only when an
infant or child must ride in front.It should be noted that vehicles without rear seats
are permitted to have an on/off switch installed for the passenger airbag;
this includes some pickup trucks and some small cars."
Old Nov 13, 2007 | 01:02 AM
SunGuy62's Avatar
anisrote,
Thx for explaining exactly which airbag you're wanting to disable. In the model years after yours, MB included a dash mounted button for just this purpose...disable the passernger side-front airbag. I have it in my '99, but don't know the specific model year when this 'feature' was added. The point being, if I owned your car and wanted to do what you indicate, my approach would be to get the wiring harness and on/off button and whatever other ancillary electronics it would take, to perform as if installed at the factory, i.e., a more modern setup.
This may run into some money as when MB adds a feature, like this airbag disable thing, it's often a tad more than get the harness, plug and play. You may want to check with these guys -http://www.oempartsdirect.com/, for oem discounted parts/components.
Bob
imosh
Dec 28, 2007 07:41 AM
himalophile
Jul 3, 2006 04:10 PM
aspat
May 7, 2006 11:53 PM
27ball
Nov 28, 2005 04:52 PM
EOLJR
Oct 1, 2005 05:04 PM
