increase timing chain tension by cranking
Old Nov 28, 2017 | 01:53 PM
charlie512's Avatar
Default increase timing chain tension by cranking
I have not started my 1987 560sl in quite a while. I was advised to crank it for a bit before starting. This would splash some oil around and most importantly (I was told) increase the tension of the tensioner (hydraulically). I once saw a mechanic stick something in the OBD connector that inhibited ignition. It's a nine pin connector and I want to short the correct pins so as to inhibit ignition. I noticed pins 3 and 4 had a paint mark on them so I am thinking he shorted those pins. Any ideas??
I know I can remove the wire to the coil, but it's kind of corroded on.
Junger
Mar 20, 2013 05:38 PM
Slkboi2000
Sep 5, 2006 07:01 AM
ventunz
Apr 16, 2006 11:29 AM
Asild
Mar 9, 2004 03:42 AM
Zoid
Jul 11, 2003 03:39 AM
