Cannot start my 380SL 1983
Old May 31, 2009 | 07:11 AM
Henry.Bucki's Avatar
Default Cannot start my 380SL 1983
Engine ran rough then quit. Replaced fuel pump and fuel filter. Still will not start. Engine just turns over. I replaced the electronic ignition box a few months ago. There is a spark. Cannot drive car to local Merc. garage. Stuck.Can anyone help - please? Thanks, Henry
Old Mar 9, 2011 | 07:03 PM
Koolrunning's Avatar
I am having the same problem you are having, changed both fuel pump and filter. Could you tell me what you did to get it started? Thanks
Old Mar 10, 2011 | 07:32 PM
Pops's Avatar
Default Not starting
I had this problem and replaced the speed control relay under the dash on passenger side of vehicle. Before buying one check it to see if there are any loose connections or broken contact leads. I bought one and still had problems, I checked after the purchase and found out it had a broken contact. Hope this helps...
E300Denmark
May 31, 2011 10:37 AM
humer_al
Aug 3, 2010 01:21 PM
hellgrace5
Jun 30, 2010 01:17 AM
hellgrace5
Mercedes A Class
Jun 21, 2010 04:02 AM
Jack21
May 4, 2010 10:23 PM
