2006 sl 55
My customer has a 2006 SL55 AMG and his panel says intorior accessories not avalible.
His steering wheel wont adjust and his seat wont adjust. He tried replacing the fuse because it burnt out and it worked agian for awhil longer then stopped working agian and this time the fuse is ok. What might cause this? I will be checking car out for the next two days to see what electrical is causing it, have not had a chance to get to this car yet. Just curius if there is a TSB or maybe this was a common problem, or someone else here had the same problem. |
battery voltage could be the issue, could need a systems battery/main battrey. the small battrey under the hood is the starter battery.
Originally Posted by chassis221
(Post 153899)
| All times are GMT -5. The time now is 05:39 AM. |
