-   Mercedes SL Class (https://mercedesforum.com/forum/mercedes-sl-class-15/)
-   -   1995 SL600 - Strange Wiper & Turn Signal Issue (https://mercedesforum.com/forum/mercedes-sl-class-15/1995-sl600-strange-wiper-turn-signal-issue-43362/)
houstoncarnut Jul 2, 2010 05:38 PM
I'd appreciate any help you can provide. I have a 1995 SL600. Recently when I try to start the wiper blade it either doesn't work at all or goes 1/2 way and stops. Then, the turn signals won't work until the next time I drive the car (the turn signals then work fine). Any idea what this might be? Thanks.
chassis221 Jul 2, 2010 07:53 PM
wiper arm might need to be lubricated ..it has a piston that gets dry and lubricating it usually helps.
turn signal stalk could be bad. both operate on the same switch. ive replaced many in the past for various reasons. but youll want to make sure it is the stalk before getting it fixed. usually when the stalks are bad the wipers or signals will operate when one or the other is used.
houstoncarnut Jul 2, 2010 08:06 PM
Thank you! How do I determine if stalk is bad? I'm not even sure what stalk is :-)
Also, how do I lubricate wiper piston? Do I need to take off wiper arm? If so how and what next? Thanks for helping a novice!
kurtdaniel Aug 23, 2010 10:28 AM
Originally Posted by houstoncarnut (Post 138089)
I'd appreciate any help you can provide. I have a 1995 SL600. Recently when I try to start the wiper blade it either doesn't work at all or goes 1/2 way and stops. Then, the turn signal switch won't work until the next time I drive the car (the turn signals then work fine). Any idea what this might be? Thanks.
same with my car. I took all the fuses out and put them back in again. Then I jiggled most of the wires going into the fuse panel and now the turn signals work! This car is very weird!
savage510 Apr 14, 2011 03:12 PM
hey chassis since u said you've replaced many combo switches i have a question. i have a sl500 with a broken combo switch, i bought the part but would like to know how straight forward the repair will be, any tips would be helpful. any special tools?thanks
