1994 SL600 suspension problem
My 1994 SL600 with 40,000 miles developed a suspension fluid leak near the front leveling valve. The leak was on a block attached to a manafold where all of the pressure lines attach. I replaced the O rings and the leaking stoped but the front shocks are pumped up thght and the rear are down low.
Any suggestions on how to resolve?? |
RE: 1994 SL600 suspension problem
Where are the oil rings,mine has a minor leak too.
My leak was in a check valve that is attached to the fluid distrubition valve behind the right front wheel. I had to make a spanner wrench to remove the bolt and re o ring it. Then I found out the special procedure for bleeding the system.
