1990 SL 500 FUSE /ELECTRICAL PROBLEMS
Old Mar 17, 2007 | 08:35 PM
Curt Aigner's Avatar
Default 1990 SL 500 FUSE /ELECTRICAL PROBLEMS
I have a 1990 SL500 w/19,000 original miles. The car sat all winter and now has a dead battery. I jumped the car correctly and it ran fine,everything working. After a 45 min drive , I parked it and proceded to re-start it. BONE DEAD. I pulled the battery out and installed a new one correctly. Car fired up and runs no problem. Now electrically half of the car works. I have no radio,gauges,key less enrty, power locks, power seats, and most likely some others not working. I checked the fuse box under the hood and by the battery . All fuses appear good. I don't have a owners manuel or repair manuel. Are there more fuse boxes/ or fusible links somewhere else??? Any suggestions??
Old Mar 18, 2007 | 04:25 PM
TheJimer's Avatar
Default RE: 1990 SL 500 FUSE /ELECTRICAL PROBLEMS
Hi Curt,
I certainly am no expert, however, I suspect what you are experiencing is not an electrical problem.
I believe that you have to insert the radio anti-theft code to reactivate the radio once the battery has been disconnected. The key less entry and power locks may also be part of the anti-theft system; however, I can’t explain the power seats!
There may be an additional fuse panel located in the front “foot well” under the carpeting of the of the passenger side floor?
Good luck!
Jim
dogman1313
Jun 8, 2011 11:20 AM
danoffice
Apr 17, 2011 11:08 AM
tomfer114
Oct 19, 2010 07:26 AM
Wisjd
Feb 1, 2009 12:13 PM
zofitness
Jan 4, 2009 04:16 PM
