1990 300 SEL dome light
How does one access the dome light lamp located top center above the windsield? Mine is more than likely burnt out.
RE: 1990 300 SEL dome light
pry off the cover.
actually you have to remove the dome light assembly there are to clips in the back of the dome light assembly you can push them foward with a pocket screwdriver. then replaced the bulb
